Jspazz,
I have never metered exact flow, it is an M10 nozzle, and the pump is a high quality 250psi pump from Alky Control.
It is set to go on around 5-6psi because the car builds boost so fast. Also, it is not a progressive rpm controller, it is a progressive map based sensor.
I have a 2.5bar(I believe) map sensor plugged into the boost tap at the charger entry. The controller uses voltage output from the map sensor and has an initial and progressive setting.
Initial - voltage input received triggers the pump
Progressive - sets the starting flow amount once initial is triggered, then depending on the progressive knob setting, will increase voltage to the pump based on the voltage it is receiving from the map sensor.
If it helps, I explained my max 18psi pressure to Julio from alky control and he believes that at 18psi with the progressive know turned almost all the way up, I am extremely close to maxing the M10 nozzle.
I would love to explain everything I’ve seem in my logs when I started spraying; including some interesting notes on what happens when you reset fuel trims. There is just too much to type.
