Some days the engine seems to purr at idle like a happy kitten––even on cold starts. And other times it’s just janky. I can’t seem to get a bead on the pattern or the cause. But I’m wondering if the random nature of these faults suggests and electrical problem and not mechanical. (I should add that the engine seems to always run fine at speed.) Any thoughts?
see: Intermittent codes - diagnose electrical or mechanical problem?
A couple of weekends ago, the car was running so smoothly I even commented about it out loud (and neglected to knock on wood…) Then I stopped by the roadside fruit stand to buy some strawberries, and 5m later, on restart, I get a rough idle with these codes:
P0171 (pending) - System Too Lean Bank 1
(confirmed) - System Too Lean Bank 1
P0174 (pending) - System Too Lean Bank 2
P1075 (pending)
P1077 (pending)
see: System Too Lean codes
I’ve checked for vacuum leaks around the oil separator and TBs, but nothing shows up with the carb cleaner test.
Then yesterday I got an EPC fault/limp mode after shopping at the grocery store (on the way out the car was perfect) I couldn’t even clear the fault with the Carista:
P0638 (pending) - Throttle Actuator Control Range/Performance Bank 1
P2101 (pending) - Throttle Actuator “A” Control Motor Circuit Range/Performance
P2106 (pending) - Throttle Actuator Control System - Forced Limited Power
I had an earlier battle with these codes that ultimately seemed to be solved by zip ties to the electrical harness:
P0023 - “B” Camshaft Position - Actuator Circuit/Open Bank 2
P1060 - Bank 2, cam shaft adjustment discharge opening, interruption
see: [SOLVED?] P0023 - “B” Camshaft Position - Actuator Circuit/Open Bank 2
With that in mind, I checked all the electrical connections again. I cleaned the electrical connector to the Bank1 TB, and also checked ECU2 because I know it is bouncing around unsecured. I think a tab must have broken off somewhere.
QUESTION:
Can someone tell me what the ECU is sitting on? It feels like some kind of air box and I can tell that the back right corner of the “lid” is loose. It feels like a screw is missing back there and I’m wondering if that is contributing to the “engine too lean” fault.
Otherwise, I was able to shove a wine cork on the front left corner of ECU2 to keep the unit pinned under the remaining tabs. We’ll see how that holds up.
But those 2 changes seems to have fixed the TB/limp mode faults and the car seems fine on the first test drive. If anyone has any other ideas, please share. Until then, stay tuned…
